It is currently Wed Nov 25, 2026 11:12 am
PostPosted: Sat Jun 28, 2003 7:25 pm
I've made some progress on the Turbo Dart. Thanks to all who responded to my last question about the black smoke It's still running a bit questionably, but the arid smoke went away when I found and capped a massive vacuum leak. I think I'll give the carb a thorough cleaning, as it's a used carb and may be gunked up. However, I only got about 20 feet before realizing I'd left an unacceptable trail of oil and had to put it back in the garage. Seems like my attempt at returning the oil through a hole drilled in the block really isn't working out, and I will have to bite the bullet and stick the return line into a fitting in the oil pan like it ough to be. Is it possible to pull the oil pan with the engine still in the car? Is there any trick to it? The car is a '66 Dart with power steering.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sat Jun 28, 2003 8:05 pm
I was just underneath the '70 Swinger today that I've been working on bit by bit, trying to find a good way to do the same thing, and I don't think there really is any easy way to pull the pan.
It looks to me like you've gotta drop the center link for the steering, then raise up the engine a few inches with a hoist to get enough clearance between the pan and the K frame to pull it off. I wish there were an easier way, but I can't for the life of me think of anything.
PostPosted: Sat Jun 28, 2003 8:29 pm
The service manual for my 71 duster says to drop the centerlink and raise engine up a bit. Although I think I read somewhere on this forum that instead of completely removing the center link you can disassemble one side and swing it out of the way.
PostPosted: Mon Jul 07, 2003 7:32 pm
I have a "66 Dart (w/ manual steering). The factory manual says to remove the center link (you might be able to free one end and swing it out of the way- worth a try) and raise the engine. It mentions rotating the crank to get clearance from counterweights as well.
Good Luck!
JLC of Ridgefield USA
PostPosted: Mon Jul 07, 2003 10:32 pm
When I dropped the pan on my 73 duster is wasn't a big job once I took the right aproach. I just disconnected one end of the center link so it could be swung out of the way, then I had to jack the engine up a couple inches so the pan could clear the k-member. All I needed for the job were 1/4" and 1/2" drive ratchets, a puller for the center link, a jack and jack stands.
PostPosted: Mon Jul 07, 2003 10:36 pm
I had to remove the whole centerlink, and get the engine lifted (some bolts are above the k-member(buried by it...), if you loosen the motor mounts, you actually can use a socket and a ratchet instead of wrench....
thankfully the car had no spindles or LCA's but it was still a pain removing the idler arm...
PostPosted: Thu Jul 10, 2003 10:25 am
...make sure you turn the crank so the front counterweights are out of your way (up in the block). I forgot this step a few months ago and was catching hell until it dawned on me what I was doing wrong. Duh.
"DW"
If it ain't broke, fix it!
 Post subject: Thanks, everyone!
PostPosted: Thu Jul 10, 2003 6:16 pm
Looks like it's going to be a bit difficult after all. Time to get a new pickle fork to replace the one I broke last time I did any suspension work.
BTW, where did you put the jack to lift the motor?
PostPosted: Thu Jul 10, 2003 8:39 pm
I was able to put an oil return line in my oil pan without removing it. I used a hole saw to drill a 3/4 inch hole right thru the hole in the left front motor mount. This placed the hole above the oil level. The hole saw will usually retain the plug, but even if it doesn't I don't think it would be a problem. I drained the oil and then used a couple of cans of engine flush to flush out any metal chips. Then I used a 5/8 hose barb to 1/2 inch NPT pipe thread fitting that self threaded into the drilled hole. Actually, I also used 1/2 inch NPT male and female adaptors to extend the hose barb fitting out far enough to get at it with the hose and clamp. I then used an AN-10 braided hose to connect to the turbo. To insure against leakage where the fitting screws into the pan, I threaded a "nut" on the fitting and used an oil plug gasket between this "nut" and the oil pan. The "nut" came from one of those fittings that go into electrical junction boxes and hold the metal-shielded wire in place. I got all of this stuff at Home Depot. For the return line at the turbo I got an adapter from Road Race Engineering ( www.roadraceengineering.com , Garret oil drain flange with 5/8 inch hose barb fitting, $13). This allows the use of a 5/8 inch (AN-10) hose in place of the metal return line that was originally used.
Bob D
PostPosted: Thu Jul 10, 2003 9:47 pm
You won't need a "pickle fork" for this job unless you're making hamburgers! A couple wrenches will be needed for the idler arm big end, and Idiot Auto Parts will lend you a Pitman arm puller if you don't have one. You just have to get things down out of the way. I guess you could unhook the centerlink where it hooks to the idler/Pitman arms, but it'll be messier and I wouldn't recommend using a pickle fork on anything to be re-used. Try using a small gear puller if you're going to do it that way. The pickle fork tears things up and puts a lot of stress in the joint.
Get a good size piece of wood and carefully jack the motor from the bottom of the pan with the driver's-side mount loose. Wedge another suitable piece of wood between the mount and frame when you've got it lifted a few inches. I have sucessfully and without incident jacked the motor under the crank pulleys after making sure the load was spread out real carefully, but it is generally not advisable that you attempt this. Oh, yeah, make sure you take the fan shroud loose first!
"DW"
 Post subject: Thanks, Dennis!
PostPosted: Fri Jul 11, 2003 7:40 pm
It hadn't occurred to me that I could leave the tie rods connected to the center link. That'll make it a bit easier - and I do have a Pitman arm puller.
Bob, that sounds interesting but I don't know if I could get a drill where I need it in my engine compartment without taking a lot more things apart than the oil pan.
PostPosted: Sat Jul 12, 2003 8:25 pm
What position should the crank be at for pulling the pan? TDC work?
PostPosted: Sun Jul 13, 2003 2:13 am
The crank needs to be turned so that the counterweights and throws are as far up in the block as possible at the front of the engine. You can see where it needs to be after you get the pan loose and hanging down a few inches.
"DW"
PostPosted: Tue Jul 15, 2003 1:21 pm
Nothin' really new in my answer, but I just got through replacing the motor mounts and the oil pan damaged by the collapsed mounts in my '66 Valiant. I hoisted the engine and had to drop the entire center linkage. I tried to do just one side and swing it out of the way, but it wasn't enough...I had to do the whole thing. It was worth it though...no more oil leakage! :P
It ain't what you buy, it's what you build!
PostPosted: Tue Jul 15, 2003 1:30 pm
If you free the Pitman arm and Idler arm from the car, you can drop down the whole works with plenty of room to take the pan out. I've done it many times. Pushing the rears of the front tires towards each other provides plenty of slack once everything's loose. Of course, there IS more than one way to skin a cat.....
"DW"
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
