Help! No Compression
https://slantsix.org/forum/viewtopic.php?t=62810
Page 1 of 1
Author:  slantsix64 [ Thu Sep 06, 2018 10:27 am ]
Post subject:  Help! No Compression
I got my head redone and milled, put it back on and wont start i do a compression test and i have 0 compression i torqued the heads to 70 ft pounds new head gasket etc , i installed a new camshaft and timing gears as well everything lined up any ideas?
Author:  slantzilla [ Thu Sep 06, 2018 10:48 am ]
Post subject:  Re: Help! No Compression
Did you adjust the valves? Timing chain on right?
Author:  slantsix64 [ Thu Sep 06, 2018 1:23 pm ]
Your correct i had to loosen up the lash and Boom i had 155 psi on very cylinder thanks! :roll:
Author:  slantzilla [ Thu Sep 06, 2018 3:07 pm ]
:D :D
