Steering column bearing
https://slantsix.org/forum/viewtopic.php?t=62829
Page 1 of 1
Author:  coconuteater64 [ Thu Sep 13, 2018 6:19 pm ]
Post subject:  Steering column bearing
I searched all over, but I can't find any info on the correct upper steering column bearing. I disassembled my steering column to replace the ignition switch, and I noticed that the rubber around the bearing was ragged. I took the bearing out and cleaned it up and regressed it, but it sure has a lot of slop. Any ideas? It's for my 1984 D100 without tilt wheel.
Author:  dirtyd100 [ Fri Sep 14, 2018 6:55 am ]
Post subject:  Re: Steering column bearing
I have looked, but have not found one anywhere. Been working on other things but would love to get mine replaced sooner rather than later due to the rattles and squeaking. Hopefully one of the sages on here will help out. I looked for numbers to see if Fastenal could cross it to another part number they could source but I could not read all the numbers.
Author:  coconuteater64 [ Sat Sep 15, 2018 7:44 am ]
My bearing didn't have any numbers on it, and I'm sure it's long out of production. Hopefully someone has an idea.
Author:  DadTruck [ Thu Oct 25, 2018 5:49 pm ]
hello, just noticed this post,
the images are from a 84-85 D150 tilt steering wheel parts catalogue
hope this helps,
File comment: tilt steering column items
Author:  matv91 [ Fri Oct 26, 2018 4:34 am ]
https://www.factorychryslerparts.com/sh ... eLine=7337
Author:  matv91 [ Fri Oct 26, 2018 5:00 am ]
https://www.google.com/search?biw=1242& ... r4hWx1SqxM:
Author:  coconuteater64 [ Fri Oct 26, 2018 5:43 pm ]
Thanks, guys! I'm afraid the part is out of production, but if I'm reading it right one from an early Jeep will fit. The tilt wheel bearing is a GM part and is different from the standard column.
Author:  DadTruck [ Fri Oct 26, 2018 8:07 pm ]
There is a local company, Bearing Headquarters, that bills themselves as
specialists in bearings, either them or some similar company local to you may
be able to cross reference a replacement bearing.
Author:  emsvitil [ Fri Oct 26, 2018 8:31 pm ]
Measure it (ID,OD, thickness)and see if you can match the dimensions to a common bearing.
You might be able to make a common bearing size work with some shims for ID and/or OD differences.
Author:  coconuteater64 [ Mon Oct 29, 2018 9:34 am ]
That's what I'm planning. I've been out of work sick for the past week so I'm still catching up on my To Do list.
The dimensions of the bearing are as follows:
Inside Diameter: 3/4"
Outside Diameter: 1 3/16"
Thickness: 9/32"
Author:  coconuteater64 [ Mon Oct 29, 2018 11:32 am ]
Thanks for the input; I may hit them up in the future. I was able to source a used part in good shape for the price of removing it myself. It didn't have any numbers on it, but it's not worn out so I'll be able to clean it up, regrease it, and plop it in.
Author:  emsvitil [ Mon Oct 29, 2018 4:39 pm ]
Also check for a part number on the grease shield...…………….
Author:  coconuteater64 [ Mon Oct 29, 2018 4:41 pm ]
Nothing there either.
