| Startup after 10 years sitting https://slantsix.org/forum/viewtopic.php?t=62842 |
| Author: | imnoisydart [ Tue Sep 18, 2018 5:27 pm ] |
| Post subject: | Startup after 10 years sitting |
69 Dart 225. Ran at M.A.T.S 2006, drove on street couple years, then other stuff took over. Since u never lose the Slant bug, I need some advice. What is the socket size to put on a breaker bar to slowly rotate the engine ? Car has 390 Holley so I’ll need new gaskets. Plan in the future is to put Marvel Mystery Oil down the spark plug holes and let it sit a few days before slowly rotating. Any other tips greatly appreciated. Thanks, imnoisydart |
| Author: | imnoisydart [ Tue Sep 18, 2018 5:31 pm ] |
| Post subject: | Re: Startup after 10 years sitting |
Haven’t posted in a few years. Wanted it in Engines. Maybe someone can move it as I don’t remember how to post a new topic in a message section |
| Author: | bboogieart [ Wed Sep 19, 2018 7:15 am ] |
1 1/4" |
| Author: | coconuteater64 [ Tue Oct 02, 2018 5:59 am ] |
Avoid the temptation to just wail on it with the starter once you break it free with the breaker bar. That could shatter the rings and bend pushrods. I've done this a few times and the marvel mystery oil is a good idea, but make sure you spin it over a few times with the spark plugs out to squirt any leftover MMO out before trying to start. Also, watch the valvetrain to make sure everything is moving. |
| Author: | imnoisydart [ Tue Oct 02, 2018 8:17 pm ] |
Thanks coconut. Slow and easy after a time of soaking with the MM oil |
