| Lifting engine off center link https://slantsix.org/forum/viewtopic.php?t=6286 |
| Author: | Spazus [ Tue Jul 15, 2003 12:57 pm ] |
| Post subject: | Lifting engine off center link |
Hi gang, Almost done with my engine swap. Delayed by a much needed vacation. Is there any trick to getting the engine up off the center link before tightening the motor mount nuts? Tom |
| Author: | Doc [ Tue Jul 15, 2003 1:04 pm ] |
| Post subject: | Re: Lifting engine off center link |
Quote: Hi gang,
Almost done with my engine swap. Delayed by a much needed vacation. Is there any trick to getting the engine up off the center link before tightening the motor mount nuts? Tom Is the engine bolted to the transmission? Does it have the correct oil pan on it? (need more info.) DD |
| Author: | kesteb [ Tue Jul 15, 2003 1:13 pm ] |
Did you put a \6 from a F-body into an early A-body? If you did the oil pan rests on the centerlink. The only fixes are to dent the oil pan or use a V8 centerlink or use the OEM oil pan. |
| Author: | Spazus [ Tue Jul 15, 2003 1:24 pm ] |
| Post subject: | Answers to Qs |
Is the engine bolted to the transmission? YES Does it have the correct oil pan on it? YES I'm using the oil pan from a /6 225. There is a 1/2" to 3/4" vertical groove where the mounts fit. I just need to get the engine lifted up a little higher before tightening down. FYI: The mounts are brand new. p.s. The speed of the replies on this web site amazes me. I will make another donation soon. T. |
| Author: | Doc [ Tue Jul 15, 2003 1:47 pm ] |
| Post subject: | Play...Name that oil pan... |
Ok, so which 225 SL6 oil pan are you using?? http://www.dutra.org/pictures/engine/parts/oilpans.jpg And what chassis is the engine going into? (year and model) DD |
| Author: | Spazus [ Wed Jul 16, 2003 2:47 am ] |
| Post subject: | More answers |
I believe it is the blue one (my car is across the river and I don't have access to it at 2:30 a.m.) It goes in a '66 Dart GT. The replacement engine has the same engine ID as the one that was in there- 2806830 RH. T. |
