| sure-trac 7 3/4? https://slantsix.org/forum/viewtopic.php?t=6288 |
Page 1 of 2 |
| Author: | 6gun [ Tue Jul 15, 2003 1:15 pm ] |
| Post subject: | sure-trac 7 3/4? |
| Author: | Dennis Weaver [ Tue Jul 15, 2003 1:18 pm ] |
If you lift one wheel and have the trans in park, no, the wheel won't turn. You have a regular ole' open differential. "DW" |
| Author: | 6gun [ Tue Jul 15, 2003 1:28 pm ] |
| Author: | Dennis Weaver [ Tue Jul 15, 2003 1:41 pm ] |
You DO have something special... A 1966 Plymouth Valiant! P. S. - I like your signature blurb... It reminds me of another saying I heard once at some car show: "If you didn't build it, it's not REALLY yours" |
| Author: | 6gun [ Tue Jul 15, 2003 2:13 pm ] |
P.S. My signature is also on a custom license plate frame on the back of the Valiant...thx for the flower.... |
| Author: | Charrlie_S [ Wed Jul 23, 2003 5:05 am ] |
6gun, there are 7 1/4 suregrip units, but they are hard to find. I have two 7 1/4 suregrip rears. One has 3.91 gears, and the other 5.13's. Both gear sets are factory Mopar. |
| Author: | Guest [ Wed Jul 23, 2003 3:03 pm ] |
Maybe I better check real close, Charlie...I may have something here... |
| Author: | Bruce Johnson [ Mon Jul 28, 2003 5:28 pm ] |
To Charrlie S. or anyone who wants to jump in,, is there any easy way to identify a 7 1/4 sure grip at the wrecking yard? Also, what year cars should I be looking at? Thanks, Bruce J. |
| Author: | moose340 [ Mon Jul 28, 2003 7:34 pm ] |
| Post subject: | 7 1/4" SURGRIPS |
Well just to let you know, Randy's Ring and pinion sells suregrip units for the 7 1/4 rearends. I forgot the website but his ad is in every Mopar mag. |
| Author: | v8440 [ Tue Jul 29, 2003 6:00 am ] |
Quote: 6gun, there are 7 1/4 suregrip units, but they are hard to find. I have two 7 1/4 suregrip rears. One has 3.91 gears, and the other 5.13's. Both gear sets are factory Mopar.
What did they come in? It's hard for me to imagine anyone bothering with 5.13's in a 7 1/4. It seems like anything that could use them would break a 7 1/4.
| Author: | Charrlie_S [ Tue Jul 29, 2003 8:24 am ] |
To be honest, I don't remember where I got the 3.91 S.G. setup. Have been using it since 1974. The 3.91 was available from the factory in the car. The 5.13 was available from "Direct Connection". In the "old days" stock eliminator, was required to run the correct rear for the car, and the lowest ratio available was 3.91, so DC cam out with 4.10, 4.56, 4.88, 5.13. I think that is correct. All of those gears are hard to find today. Randy's Ring and Pinion, does have some 4.10's. I use the 3.91 with a 22 inch tall slick for the 1/4 mile, and the 5.13 with a 26 in tall slick for the 1/8. I have changed to a 8 3/4 rear since last season. Figured I was pushing the 7 1/4 a little too hard. The Cuda weighs 3200 lbs, and goes mid 13's, with a 1.80 short time. |
| Author: | v8440 [ Tue Jul 29, 2003 8:26 am ] |
Wow, I'm really surprised the 7 1/4 held up to what you were doing. I've never broken one myself, but I always read the horror stories about spider gears bouncing down the street. I have a '74 duster with a 225 that came with an 8 1/4. I've always thought that was kind of odd. Maybe they just were short on 7 1/4's that day. |
| Author: | Charrlie_S [ Tue Jul 29, 2003 9:19 am ] |
Spider gears are a problem. I woudn't consider a 7 1/4 without a sure grip. Wth a suregrip the spiders do not handle all the power. Also I am running an automatic, which doesn't shock the gears like a stick would. You also want the minimum amount of back lash, and proper tooth contact. |
| Author: | Pierre [ Tue Jul 29, 2003 10:02 am ] |
v8440, you know whats even more shocking? When I found out some /6 cars came stock with 8 3/4's even |
| Author: | v8440 [ Tue Jul 29, 2003 10:05 am ] |
Damn, that IS shocking. What extreme torque? Did they offer a nitrous kit as an option? J/K of course. It's hard for me to imagine a stock slant six making enough torque to seriously threaten the life of ANY drivetrain part, no matter how hard you run it. |
| Page 1 of 2 | All times are UTC-07:00 |
