| Fitting a 69 VF slant up to my 67 904 torqueflite trans? https://slantsix.org/forum/viewtopic.php?t=62891 |
| Author: | 67regal [ Tue Oct 02, 2018 10:53 pm ] |
| Post subject: | Fitting a 69 VF slant up to my 67 904 torqueflite trans? |
Hey guys, I've base that chrysler changed Flexplate and other parts between the 67 and 68 up motors.... abd that I may have trouble bolting up a VF 225 to my 67 trans and torque converter? Can anyone help me out with this one? I was hoping it would be a simple as removing my 67 motor and doing in a rebuit VF motor. Thanks for any advice. |
| Author: | slantzilla [ Tue Oct 02, 2018 10:55 pm ] |
| Post subject: | Re: Fitting a 69 VF slant up to my 67 904 torqueflite trans? |
Putting a late motor on an early trans us easy. You just need a spacer ring to go in the crank. Charlie_S on here sells them. |
| Author: | Charrlie_S [ Wed Oct 03, 2018 2:09 am ] |
If the VF is 1968 or later, and your engines/trans changed the same years as the USA engines. 68 up engine, and 67 down torqueflyte, use: 68 up flexplate 67 down converter adapter bushing in the crank pocket. I do sell the bushing, but shipping to you is a killer. Would probably be cheaper to have one made locally. |
