| Dual fuel injection https://slantsix.org/forum/viewtopic.php?t=62899 |
| Author: | 48slantp-15 [ Fri Oct 05, 2018 12:35 pm ] |
| Post subject: | Dual fuel injection |
Has anyone seen or done a dual carb fuel injection? I currently have a dual two barrel setup(not on car yet) was wondering what option u had for fuel delivery |
| Author: | lgu32 [ Sun Oct 07, 2018 1:28 am ] |
| Post subject: | Re: Dual fuel injection |
The one I have built for /6 is close to "true dual". I have 6 injectors in one group, 2 barrel throttle body and all the feedback for ECU (MAP, O2) has taken from cylinders 1-2-3. 4-5-6 will work like "slave". So just get 2 identical throttle bodies, sync them and do the control either from front of rear group of cylinders with control system you like to use. I had my own design but the same will work with almost all control systems. |
| Author: | Dart270 [ Sun Oct 07, 2018 3:07 am ] |
I am not sure what you mean by "dual carb"? Are you talking about throttle bodies or? Lou |
| Author: | lgu32 [ Sun Oct 07, 2018 7:30 am ] |
https://www.shop.cliffordperformance.ne ... 01M225.htm Like this I quess. |
| Author: | OGLeanDart270 [ Sun Oct 07, 2018 10:41 am ] |
I have seen an International Harvester engine with dual tbi. Think the company that did it was Hamilton Fuel Injection. http://www.binderplanet.com/forums/inde ... lt.120966/ That one is two one barrels, I think its 670 cfm between the two but I'm not positive. You could do two of the 2bbl units but would be overkill for sure. Brandon |
