It is currently Sat Nov 21, 2026 11:59 am
 Post subject: won't start
PostPosted: Fri Oct 12, 2018 11:08 am
Hi Guys
Well something gone wrong the car has 7000 on it and now it won't start, it started to stumble and then quite. I have tried a new 4 pin module, a new coil pick up, and another coil. checked to make sure that I was getting 12v to the coil and also when cranking. Tried grounding out the coil wire looking for spark and found none, maybe doing this wrong ? not sure. Check the oms on the coil & pick up Ok. also disconnect the tach just in case. I have been at this for 3 days HELP. I just don't know what to try next ??
Mike
 Post subject: Re: won't start
PostPosted: Fri Oct 12, 2018 3:48 pm
I think tomorrow I will take it all out and work on the bench until I get spark
Thanks
PostPosted: Fri Oct 12, 2018 6:16 pm
Is there power to the coil in 'Start' and 'Run'? The wire through the bulkhead connector is notorious for corroding just enough to lose contact.
Also, is there gas getting go the carb?
PostPosted: Sat Oct 13, 2018 3:28 pm
It fired, I had a bum 4 pin.
Thanks
PostPosted: Sat Oct 13, 2018 6:55 pm
Nice hearing from you Mike. I remember meeting you at one of the western races a long time ago.
