| how to check for hardened valve seats https://slantsix.org/forum/viewtopic.php?t=62940 |
| Author: | zuckerman [ Sat Oct 20, 2018 7:40 am ] |
| Post subject: | how to check for hardened valve seats |
I picked up a 225 slant6 engine that has mismatched parts, block is a 1969-70, head is a 1964-66, it has an electronic dist... and my >guess< is that the head has had a valve job done at some time in its past, just based on its' age. However, I do not know if the head has had the OEM soft exhaust valve seats replaced with hardened ones. Because >if< it has had the seats replaced w/hard before, I'd rather not pay to have them replaced again...(unless of course they need to be). My plan is to >use< this engine in a truck, no once a month babying...so I think it needs the hard seats... So my question is: How do I check for hard valve seats? |
| Author: | slantzilla [ Mon Oct 22, 2018 9:32 am ] |
| Post subject: | Re: how to check for hardened valve seats |
You should be able to see them. They are a ring shaped insert that is machined into the head. They will be a somewhat different color than the original head. |
| Author: | zuckerman [ Mon Oct 22, 2018 4:17 pm ] |
thanks for the reply .. |
