| No brake lights. https://slantsix.org/forum/viewtopic.php?t=62960 |
| Author: | mynameisearl [ Mon Oct 29, 2018 1:43 pm ] |
| Post subject: | No brake lights. |
1975 dart sport. I have no brake lights. Have power at the foot pedal switch, but still no lights. Any ideas? Could this be a problem with the infamous bulkhead plugs? HELP! |
| Author: | GTS225 [ Mon Oct 29, 2018 5:37 pm ] |
| Post subject: | Re: No brake lights. |
Could be, but do you have both, power in, and out, of the switch? Checked the bulbs? Might be that both are blown for some reason. Roger |
| Author: | Badvert65 [ Mon Oct 29, 2018 5:40 pm ] |
Another problem area is the turn signal switch. The brake lights go through that. |
| Author: | FrankRaso [ Tue Oct 30, 2018 10:21 am ] |
This summer, I had a problem with my stop lamp switch. The switch mechanism had come apart so the push rod had pulled out of the contact head. I put it back together with crazy glue and is again working properly. |
| Author: | mynameisearl [ Tue Oct 30, 2018 4:33 pm ] |
Thanks for all the great tips. Turned out to be the turn signal switch. I managed to clean it up and get the brake lights working. I’ll order a new switch as soon as I can find one. |
| Author: | FrankRaso [ Tue Oct 30, 2018 4:56 pm ] |
SlantSixDan has turn signal switches. Scroll all the way down to the bottom of the following page: Daniel Stern Lighting - Products |
| Author: | mynameisearl [ Tue Oct 30, 2018 7:05 pm ] |
Bought it. Thanks |
