| Yale Forklift https://slantsix.org/forum/viewtopic.php?t=62981 |
| Author: | Leafangel [ Mon Nov 05, 2018 6:25 pm ] |
| Post subject: | Yale Forklift |
We have a 14K lb forklift with a Chrysler slant 6 on propane. We would like to switch it from propane to gasoline as it is used mostly outdoors. Would this conversion be as simple as removing the propane system and replacing it with a carburetor and accompanying fuel system? What else would we need to change or modify? Thanks in advance! |
| Author: | coconuteater64 [ Tue Nov 06, 2018 7:37 am ] |
| Post subject: | Re: Yale Forklift |
We had such a forklift at the airport, and it was as simple as adding a fuel pump, carburetor, and distributor. The distributor on it had no advance and had points, so this is a good time for a HEI conversion if that's the case with yours. I don't remember how the carb linkage was hooked up though. |
