hydraulic slant block-mechanical cam??
https://slantsix.org/forum/viewtopic.php?t=63033
Page 1 of 1
Author:  Badvert65 [ Fri Nov 23, 2018 10:12 am ]
Post subject:  hydraulic slant block-mechanical cam??
I have a question about the later hydraulic cam slant engines. Can I simply swap in a mechanical cam/hardware and run with it? Where any changes made to the block to accommodate the hydraulic lifters?
Author:  THOR [ Fri Nov 23, 2018 10:55 am ]
Post subject:  Re: hydraulic slant block-mechanical cam??
Here are some references:
http://www.slantsix.org/forum/viewtopic.php?t=46756
http://slantsix.org/forum/viewtopic.php ... id#p429229
http://slantsix.org/forum/viewtopic.php ... d&start=15
Aside from those, blocks are effectively the same, the difference is in the hardware for the valvetrain. To swap, you would need a cam, lifters, adjustable rockers, and potentially pushrods depending on what has been done to the block, head, etc.
~THOR~
Author:  Badvert65 [ Fri Nov 23, 2018 11:21 am ]
Good stuff. I am looking for another cast crank motor and if the hydraulic ones are easy to swap to mechanical, then that opens up a few more years to my search. I plan to use the earlier heads (drool tube) and the mechanical rocker assembly on the cast block. My 79 block was cast crank, solid lifter and that worked out pretty well for me.
Author:  Charrlie_S [ Fri Nov 23, 2018 12:59 pm ]
~THOR~
Must use mechanical pushrods, they are cup/ball. Hydraulic pushrods are ball/ball. Also use the cam bearings for the year of the block, not the cam.
