1966 Valiant - Firestone wide Oval Radial
https://slantsix.org/forum/viewtopic.php?t=63136
Author:  sdowney [ Wed Jan 02, 2019 10:31 am ]
Post subject:  1966 Valiant - Firestone wide Oval Radial
https://www.cokertire.com/tires/firesto ... l-rwl.html
FR72 -14 (in the drop down)
Can anyone inform me on how these will fit my 66 Valiant. I currently have 13" tires that are about 24" in diameter. At 26.40 it seems like it might be tight, I am going to Lwp with 14" rims. I like the look of these tires, just want to make sure the rim width and back spacing is correct so it does not rub on anything. Looking at all 4 corners being the same. Staying with the 170 so I wont need anything bigger. Also side note - Rebuilding front end with a front disc brake upgrade, going to go with a complete firm feel package with dropped spindles. And thoughts or advise are appreciated.
Thanks,
Author:  Greg Ondayko [ Wed Jan 02, 2019 11:23 am ]
Post subject:  Re: 1966 Valiant - Firestone wide Oval Radial
What are those equivalent to in P metric tire size?
I have Run p225 70 14 on stock backspacing 5.5" wide small bolt 5 on 4" bolt pattern Rims with no clearance issues.
