| Interchangeability Manual Shift Linkage Questions https://slantsix.org/forum/viewtopic.php?t=63138 |
| Author: | ianmcc [ Wed Jan 02, 2019 12:42 pm ] |
| Post subject: | Interchangeability Manual Shift Linkage Questions |
Done a lot of looking here and abroad but can't really find a clear answer. My 1960 Valiant has the tilted A903 manual trans but no floor shifter and no clutch linkage. I do have the z-bar and trans side bracket but no frame side ball mount. There is a guy local to me that is parting out a /6 1966 valiant manual trans with the column shifter. Question is can I use any of the clutch linkage with the floor mount z-bar? Are they different between the earlier cars? I don't want to convert over to the column shift (I am aware that the floor shifter might be hard to source). |
| Author: | ianmcc [ Thu Jan 03, 2019 1:08 pm ] |
| Post subject: | Re: Interchangeability Manual Shift Linkage Questions |
And the clutch fork linkage-is it specific to 60-62? The end looks different. |
| Author: | Rick Covalt [ Thu Jan 03, 2019 1:45 pm ] |
I never knew any of the transmissions were tilted?? Learn something new every day ! |
| Author: | kesteb [ Thu Jan 03, 2019 10:02 pm ] |
The clutch fork looks like the one in my '65, which was originally from a '64 Dart. The ball stud may be available from the Mopar transmission specialist's. They do sell a version that bolts on. The nylon bushings for the z bar seems to be the same for all years. |
| Author: | ianmcc [ Fri Jan 04, 2019 6:41 am ] |
And the best tool I just picked up (for free I might add!) is a set of SAE tap and dies in both coarse and fine threads. Only up to 5/16" but already been chasing threads. |
| Author: | kesteb [ Fri Jan 04, 2019 9:32 pm ] |
That's the same clutch setup as my '65 Dart uses. |
