| Power dropping/surging https://slantsix.org/forum/viewtopic.php?t=6315 |
| Author: | FrenchieBoy [ Fri Jul 18, 2003 9:30 am ] |
| Post subject: | Power dropping/surging |
Hi! I have a 1986 250 Van that I believe is an ex-Navy base vehicle with about 80,000 original miles. It's problem is that the power will drop or surge quite a bit with it feeling like it is running on 4/5/6 cylinders. I feel that it is a fuel problem and not a spark problem. I have changed the fuel filter (probably from the original), spark plugs, wires, pcv valve, and I believe that the previous owner changed the distributor cap and rotor. Also, I have put in a couple of tanks worth of total fuel system cleaner. Regardless of the power level (which as I indicated is stepped to feel like you have a different amount of cylinders pulling each time), the engine is very smooth regardless of rpm. However, at the highest power level (when it feels like it is running on all six) it will knock a bit when accelerating. Also, it seems less likely to have the highest power level when it is humid/raining (I live in Florida). Additionally, it invariably has almost no power when it is cold. Oh, and it has no exhaust system aft of the catalytic converter. Also, when it is very hot and you have just driven it, it doesn't like to start up--maybe like it is flooded or something. Does it need carb cleaner externally, a carb rebuild, or what? When I was in high school, my family had a van almost identical, and after a crash and rebuild, it ran like the devil. I know it should have more power, and I am sure it has excellent compression as well. Thanks for y'all's help! |
| Author: | Pierre [ Fri Jul 18, 2003 9:34 am ] |
Try redoing the timing, and make sure its steady (no vaccum leaks, worn distributor/gear) |
| Author: | v8440 [ Fri Jul 18, 2003 10:11 am ] |
All of the symptoms you give are screaming LEAN. It could be a vacuum leak, though I doubt that because it would idle poorly, and probably fast. I'd check the carburetor for trash. It could be a clogged jet or something. Or, since it's hard to start sometimes, the fuel level in the bowl could be low. If it's real low, they can run lean because the jet(s) are uncovered some of the time, and engine heat can evaporate the fuel in the bowl after shutoff if there is too little fuel in there. That would cause hard starting, as the pump would have to replenish the fuel in the bowl to get it to start. |
| Author: | Dennis Weaver [ Fri Jul 18, 2003 10:15 am ] |
If a motor is running on less than the prescribed # of cylinders, it will present itself as a dead skip(s) and that would normally be caused by an ignition or mechanical problem, not a lean/rich (fuel) problem, unless of course it is SO rich that the fuel is extinguishing the spark. I don't know what you're problem is without seeing/driving vehicle, but you might check that "catyclismic" converter and make sure it's not stopped up. Also, as Pierre said, look for the obvious like vacuum leaks etc, also suspect the EGR valve. Depending on what the law sez where you live, I'd consider snatching all the smog junk off the motor and setting it up with just the basics, standard electronic ignition (Does an '86 van have lean burn?), and ported vacuum advance source off the carb. Then at least you know what you're dealing with, but don't tell anybody I told you to do that! "DW" |
| Author: | Dennis Weaver [ Fri Jul 18, 2003 10:19 am ] |
What v8440 said! Seriously, I was working on this post before I saw yours, v8440. I agree it sounds lean, but then he's describing "running on 4, 5 cylinders", so I wanted to clarify the difference in a skip and being a slug.... "DW" |
| Author: | Reed [ Fri Jul 18, 2003 1:48 pm ] |
Fist off, does the van have a "Lean Burn" or "Spark Control Computer" system on the engine? If so, chances are that some component in the system is faulty. You can spend the time to try and trouble shoot it, but I recommend yanking the computer and swapping over to a standard electronic ignition system. Both of these computer control systems control the tming of the motor, and sometimes even the mixture of the carb. Both are known to e failure prone and both are a PITA to get running properly. Reed |
| Author: | Craig [ Fri Jul 18, 2003 10:52 pm ] |
Quote: Both of these computer control systems control the tming of the motor, and sometimes even the mixture of the carb.
Don't forget... on 1986-7 Slant powered truck/van the computer also controls the electronically controlled lock-up torque converter if your truck/van has one.[/u]
