It is currently Tue Nov 17, 2026 4:52 pm
PostPosted: Wed Jan 23, 2019 8:40 am
Car Model: 1982 D150
Hi to all,,
So, after about two years of lollygagging, I finally installed the Weber 38/38 on my 82 D150.
What a difference!!
Great power, very smooth acceleration..
I'm finally able to go faster that 68 miles per hour.
Only issue I found:
fuel seems to cut out at about 75 miles per hour.
I suspect the fuel pump because I didn't need to use the pressure regulator. My Napa electronic pump puts out a grand total of two psi. If I accelerate, pressure drops to near none.
Question. What GPH should I be looking for? Is there better brand to buy?
I've been eyeballing this one.
https://www.jegs.com/i/Carter/180/P4070/10002/-1
is 50 GPH enough?
My slant is pretty much stock except for:
HEI, Weber 38, 2.25 exhaust.
Thank you, have a great day.
Slant power!!!
At least I try...
Users browsing this forum: Amazon [Bot], Google [Bot] and 4 guests
