JB Weld on a carb?
https://slantsix.org/forum/viewtopic.php?t=6319
Author:  Jopapa [ Fri Jul 18, 2003 2:23 pm ]
Post subject:  JB Weld on a carb?
Well I finally broke the high idle cam screw off of that junker carb that I rebuilt. Only problem is that the chunk of the carb housing that holds it on came right off with it :roll:
Would you guys advise using JB Weld to fix it? I can't run out and get another junker since this was the only one I could find locally (and c'mon, for 9 bucks how you gonna beat that?).
Author:  Eric W [ Fri Jul 18, 2003 4:34 pm ]
Are you talking about the part that is part of the throttle shaft? If so, I wouln't worry about it during the summer months. Just save up and find another carb. Heck, my choke isn't even hooked up and I took my choke plate out. No problems with warming up. No biggie. Or I could give you my old carb, but its just flat worn out. If you want it to fix yours, let me know, its just rolling around in my trunk....it the Holley 1920 1bbl.
