| 904 trans convert to pushbutton https://slantsix.org/forum/viewtopic.php?t=63203 |
| Author: | Thebearded1 [ Wed Jan 23, 2019 7:40 am ] |
| Post subject: | 904 trans convert to pushbutton |
I used the search feature and couldn't find what i was looking for. If any one can send me a link to a past discussion non this that would be great. I have a 904 behind my slant six in my roadster and it is shifted using a metal linakge to a homemade "console shifter". I'd really like to put a push button shifter in this car, is that even possible? If it is possible what parts would i need to do this? I've never seen how a PB shifter woks up close so i don't know if it would be easy or not. I've seen forums on other sites of people going push button to console but not the other way around. I see people mention a shift cable and park cable/'ever when talking about PB shifters so i'm guessing this may be difficult to do what i want. I can't remember what year the trans is but i think it was a late 60s. Any help is appreciated. Thanks yall! |
| Author: | ProCycle [ Wed Jan 23, 2019 8:12 am ] |
| Post subject: | Re: 904 trans convert to pushbutton |
I believe you would need a '65 or earlier 904. They do indeed have 2 cables. One for shifting and one to lock it in park. The shift cable enters the transmission under the tailshaft housing and the park cable enters the transmission on the left side. The shift cable travel is only about an inch so an original pushbutton shifter probably couldn't easily be made to shift a later 904 with the external shift lever. I have an early 904 you could have for free... |
| Author: | Charrlie_S [ Wed Jan 23, 2019 8:27 am ] |
Quote: I used the search feature and couldn't find what i was looking for. If any one can send me a link to a past discussion non this that would be great. I have a 904 behind my slant six in my roadster and it is shifted using a metal linakge to a homemade "console shifter". I'd really like to put a push button shifter in this car, is that even possible? If it is possible what parts would i need to do this? I've never seen how a PB shifter woks up close so i don't know if it would be easy or not. I've seen forums on other sites of people going push button to console but not the other way around. I see people mention a shift cable and park cable/'ever when talking about PB shifters so i'm guessing this may be difficult to do what i want. I can't remember what year the trans is but i think it was a late 60s. Any help is appreciated.
What year is the engine and trans, you are running now? I have done several PB setups, and depending on years makes a difference. Trans is 64 down, 65, or 66-67, or 68 up. Engine 67 or older, 68 newer.Thanks yall! If you want to talk about the options, send a PM, and I'll give you my phone number. |
| Author: | Thebearded1 [ Wed Jan 23, 2019 12:06 pm ] |
Thanks for the quick responses! ProCycle Thanks for the offer! I would be on my way to get that trans if I was closer, Maryland to Oregon would be a longgg haul haha Charrlie_S I will look up my engine and trans again to see what years I have and give you a PM I just don't have much room in my model t body so if i could eliminate the console shifter that would be nice. I guess another option would be setting up a cable system instead of a rod and make a small shifter to mount on the bottom of the dash or something. |
| Author: | SpaceFrank [ Wed Jan 23, 2019 1:23 pm ] |
Quote: I believe you would need a '65 or earlier 904. They do indeed have 2 cables. One for shifting and one to lock it in park. The shift cable enters the transmission under the tailshaft housing and the park cable enters the transmission on the left side.
FYI, looks like you got your cables crossed while typing.
| Author: | ProCycle [ Wed Jan 23, 2019 1:51 pm ] |
Quote: Quote: I believe you would need a '65 or earlier 904. They do indeed have 2 cables. One for shifting and one to lock it in park. The shift cable enters the transmission under the tailshaft housing and the park cable enters the transmission on the left side.
FYI, looks like you got your cables crossed while typing.I opted for a newer 904 and B&M shifter in my '65 barracuda. |
| Author: | Thebearded1 [ Tue Jan 29, 2019 6:21 am ] |
If anyone has any ideas, the casting number on the drivers side is 2806830-6 indicating its a 225 1968-70. I wasn't able to look behind the alternator bracket to read the date code for my engine. The trans number is 351804A3456 which looks like it makes it a 71. I may use an old steering column from a 1927 chevy that has the throttle and ignition advanced lever and may try to set up one of the levers to operate the trans via a cable but haven't looked everything too closely yet. |
