1983 d100 slant six rebuild
https://slantsix.org/forum/viewtopic.php?t=63213
Author:  stevesaxton76 [ Thu Jan 24, 2019 3:38 pm ]
Post subject:  1983 d100 slant six rebuild
hello all!!,
I am new to this site and looking for some info.. I am currently working on a 1983 d100 short box pickup rebuild.. I dropped the engine off a few months ago at a local machine shop to have a long block rebuild done on it. he called me today to inform me that he believes he messed up..... he put a hydraulic cam and lifter combo in it and the original stuff was mechanical....I have read on here that the rocker tube assembly is different between each style. I actually would prefer to stay hydraulic if possible, what needs to be changed?? can I run the mechanical rocker assembly with the hydraulic cam?? will it cause any damage?? if not where can I find the correct parts I need?? HELP!!! :( :(
Author:  Charrlie_S [ Thu Jan 24, 2019 6:20 pm ]
Post subject:  Re: 1983 d100 slant six rebuild
You will need the hydraulic rocker arms, rocker shaft, and pushrods. You might need to drill the rear lower shaft mounting bolt hole larger. But that is not a problem.
Rockauto has some rocker arms, and pushrods, but no shaft listed, for a 84 dodge 225
At least the shop was upfront, to say they might have goofed.
Author:  stevesaxton76 [ Thu Jan 24, 2019 7:27 pm ]
well they did order hydraulic push rods with the cam kit... so I guess I just need the rockers?? can I modify the current mechanical tube to work??
Author:  ceej [ Thu Jan 24, 2019 8:59 pm ]
Reed did a thread that is tied to the Engine Sticky "Frequently Asked Questions"
This describes the differences. http://www.slantsix.org/forum/viewtopic.php?t=46756
Peruse this info. The rocker shaft is different.
CJ
