| Slant6 hole/port https://slantsix.org/forum/viewtopic.php?t=63305 |
| Author: | franko [ Wed Feb 13, 2019 5:58 pm ] |
| Post subject: | Slant6 hole/port |
When you remove camshaft sprocket there is a hole or port. Is there meant to be a plug in this or is it left open. Regards Franko |
| Author: | Greg Ondayko [ Wed Feb 13, 2019 6:52 pm ] |
| Post subject: | Re: Slant6 hole/port |
There is a threaded one which should have a plug... that one is the oil pressure gallery. The other one is a drain from the front lifter valley. No threads... no plug it drains onto the chain. Greg |
| Author: | franko [ Wed Feb 13, 2019 7:22 pm ] |
Thanks Greg, That’s a great help, can you also advise me on the harmonic balancer. I under stand it is pressed on the crank shaft and key way and it does not have a securing bolt. But does the balancer go all the way onto Shaft having taken some measurements the balancer appeares that it will overlap the end. Regards Franko |
| Author: | Charrlie_S [ Thu Feb 14, 2019 3:14 am ] |
The balancer is a "press" fit on the crank. Most people use a bolt and large washer to draw (press) the damper on, if not having a installation tool. Some hammer it on, but that is not desirable. The end of the crank does not come out to the end of the balancer, when the balancer is fully seated. |
| Author: | SpaceFrank [ Fri Feb 15, 2019 9:13 am ] |
I bolt on the water pump/fan pulley and crank the balancer in until the belt grooves line up by eye. (I might not be the best person to take advice from.) |
