It is currently Mon Nov 09, 2026 1:52 pm
PostPosted: Fri Feb 15, 2019 2:57 pm
Hey guys:
I'm going to edit this post, since I have solved my problem. I got confused about my throttle rod setup on my '68 and became convinced it was supposed to have some iteration of linkage and rod that it actually wasn't supposed to have because the manual I was referring to was WRONG. I finally recalled that I had downloaded the actual '68 Plymouth service manual and learned I have the proper parts after all.
Feel free to watch the video if you want...there are a couple pictures at the end of older, more obsolete rods on there.
https://www.youtube.com/watch?v=ELv9tkQ ... e=youtu.be
1966 Chrysler 300 coupe
1968 Plymouth Valiant 100
1969 Dart Custom 273 V8
PostPosted: Fri Feb 15, 2019 11:37 pm
Car Model: 1982 D150 225, 2bbl., 833 OD
Glad that you got that figured out, Tyler. I just discovered your videos about a year or so ago and have enjoyed many of them.
1982 Dodge D150 ( Ram)
225 with A833OD. 2bbl. Non power brakes
PostPosted: Sat Feb 16, 2019 7:56 am
where you using a Haynes Service manual?
