Crank scrapers, windage tray
https://slantsix.org/forum/viewtopic.php?t=63319
Page 1 of 2
Author:  Charrlie_S [ Mon Feb 18, 2019 4:37 am ]
Post subject:  Crank scrapers, windage tray
I see requests for windage trays on occasion. Since Mopar discontinued these years ago, and Mike Jeffery retired, I was not aware of any source for these.
Here is a copy of an e-mail I sent.
-----Original Message-----
To: flturbo6 <flturbo6@aol.com>
Sent: Mon, Feb 18, 2019 12:31 am
Subject: Re: Chrysler slant six windage tray
On 2019-02-17 08:11, flturbo6@aol.com wrote:
> Hi, Kevin
> Was just wondering if you have a windage tray available for the
> 170-225 mopar slant six engine. Mopar performance has not had them for
> many years. Mike Jeffery was making them, but he has retired. I get
> inquires on where to purchase, once in a while.
> Charlie Schmid (66 barracude 170 slant six)
> silver springs, fl 34488
Hi Charlie,
I will have a pattern shortly. It will be adjustable for different pans
and I also think I will make a version that does not need the 340/360
installation main bolts.
Kind regards,
Kevin
Ishihara-Johnson Crank Scrapers
http://www.crank-scrapers.com
(727) 808-8602
Author:  and739 [ Mon Feb 18, 2019 2:37 pm ]
Post subject:  Re: Crank scrapers, windage tray
Thanks Charlie!
There’s some pretty good reading at the crank-scrapers.com link at the bottom of the email.
I never knew they made Teflon zero clearance scrapers!
Author:  Charrlie_S [ Mon Feb 18, 2019 2:58 pm ]
I have known Kevin for several years. I have a couple of his crank scrappers for 170's. I lent him some short blocks, some years ago, to use for mockups.
Author:  slantzilla [ Mon Feb 18, 2019 6:50 pm ]
You do know Rick Covalt makes trays, right?
Author:  Charrlie_S [ Mon Feb 18, 2019 8:16 pm ]
No, I did not.
Author:  Badvert65 [ Tue Feb 19, 2019 4:39 am ]
Whut?
Author:  slantzilla [ Tue Feb 19, 2019 5:55 am ]
Rick got Mike's blessing when he quit.
DadTruck got the scraper patterns with the flowbench stuff.
Author:  Greg Ondayko [ Tue Feb 19, 2019 6:05 am ]
He has gotten His Metal and Body Guy to make them - they are a nice piece.
Mine is unfinished.. I need to to the final assembly and mock up on it.
Contact him about such projects.
Author:  DadTruck [ Tue Feb 19, 2019 10:08 am ]
and they probably work, but are really primitive compared to what K-J offers.
I could not find the desire to produce them since there is a much beter product
already available.
K-J only offered a forged crank slant crank scraper. Kevin and I talked on the phone a couple of
times and I sent him a marked up pattern of the changes needed to his two piece forged scraper
to make it fit a cast slant six crank. He said he has been wanting to do a scraper for a cast slant crank,
so he may have it available by now.
Author:  slantzilla [ Tue Feb 19, 2019 10:26 am ]
I have one of his scrapers in my old motor. It was not exactly a "bolt-in" piece.
I think Johnson's was $60 15 years ago. Mike's were $25 when he quit.
Author:  DadTruck [ Tue Feb 19, 2019 10:59 am ]
not sure what you bought 15 years ago, the K-J of today are a little pricy, but they are two
piece units, scrape on both the up and down crank circle. Mike had a one side flat scraper.
if one was to only purchase the one flat piece, the side that is comparable to what Mike sold, and also leave
off the swinging trap doors, then and this is my assumption, it should be comparable to Mike's price as it would
be a comparable part.
When one purchases the K-J two piece scraper, it is the 'bent' scraper that has the manufacturing cost to it.
Author:  slantzilla [ Tue Feb 19, 2019 11:46 am ]
My Ishihara-Johnson is a scraper on one side and just a spacer on the other.
I had to grind a lot to get the crank to miss it.
Author:  and739 [ Tue Feb 19, 2019 12:04 pm ]
Please tell me why the one side is bent at a 90 degree angle and what the hinged trap doors are for.
Would these be installed with a gasket on top and bottom? How is the difference in thickness made up on the ends of the oil pan?
Thanks for enduring these questions, this is new to me. :mrgreen:
Author:  Dart270 [ Tue Feb 19, 2019 12:06 pm ]
No gasket, just silicone sealer.
Author:  drgonzo [ Tue Feb 19, 2019 12:22 pm ]
I didn't make a spacer to go with my crank scraper. Is it required to get the oil pan to seal? How are you guys sealing your pan/scraper/blocks?
I see just sealer for Lou. Who else?
Page 1 of 2 All times are UTC-07:00
