It is currently Wed Nov 11, 2026 6:49 am
 Post subject: rocker arm ratios?
PostPosted: Tue Feb 19, 2019 5:56 pm
I have heard that the factory mechanical rocker arms are notorious for not actually being a true 1.5 ratio. What is the best method to check for checking the ratios of these rocker arms?
 Post subject: Re: rocker arm ratios
PostPosted: Tue Feb 19, 2019 6:19 pm
The rocker ratio is the proportional distance of the push rod side of the rocker to the valve side of the rocker with the rocker shaft as the centerline.
A garage bench method to chech the rocker ratio is to mount a rocker on a shaft, have a dial gauge zeroed on the valve side, preferably at the valve contact point, then move the push rod side a known distance. The valve side should have moved 1.5 times what the push rod side moved.
