| Long rod 225 buildup https://slantsix.org/forum/viewtopic.php?t=6333 |
| Author: | Brett K [ Sun Jul 20, 2003 11:33 am ] |
| Post subject: | Long rod 225 buildup |
I've reached a point in my long rod buildup that brings me to a question. The issue at hand is the compression ratio. I'm at approx 9:1 now, but if I go for a quench setup, it'll put me at right around 10.5:1. Given that this is going in a daily driven street car, with EFI and a 4 speed, I'm a bit torn. For those of you that have built up the 198/2.2 setup in the past, just how much compression will it handle on the street, before pump gas becomes a major issue? FYI, the current buildup looks like this: 76 225 block Forged crank (0.000/0.010) 198 rods KB 2.2 turbo pistons (+18cc Dish) Double roller timing set Stand pipes in the lifter Valley 76 Head Ford 300 valves and seals Hardened seats Ported/polished 340 Springs I'd tell you about the injeciton setup, but I want to keep it under wraps for the time being. Any thoughts on the motor/compression issue? |
| Author: | DusterIdiot [ Sun Jul 20, 2003 11:46 am ] |
| Post subject: | D |
D |
| Author: | Doctor Dodge [ Sun Jul 20, 2003 3:05 pm ] |
What cam are you going to use? Static compression / cylinder pressure and cam numbers go hand-in-hand. DD |
| Author: | Brett k. [ Sun Jul 20, 2003 3:16 pm ] |
I'm going to order the cam once I've got everything else figured... Match it to the rest of the hardware, as it were. |
| Author: | slantzilla [ Tue Jul 22, 2003 6:39 pm ] |
Mine was running at about 11-1 on pump gas. The long rod seems to make the motor very resistant to detonation. I started with a 268*/.460" Racer Brown and ended up with a .528" Mopar cam. |
| Author: | Doctor Dodge [ Tue Jul 22, 2003 8:21 pm ] |
I have 12.5 to 1 in the one I'm building now, running an Isky 505 cam. (.505 lift) my guess is that it will have 195 psi of cranking cylinder pressure, I plan to run this one on race gas . DD http://www.dutra.org/pictures/engine/du ... slant6.jpg |
