Drag/centerlink oil pan clearance?
https://slantsix.org/forum/viewtopic.php?t=63382
Author:  drgonzo [ Mon Mar 11, 2019 7:21 am ]
Post subject:  Drag/centerlink oil pan clearance?
Would changing to a 273 style center link give enough clearance to run a later model A body slant 6 oil pan in a '63 Dart?
Author:  Rick Covalt [ Mon Mar 11, 2019 9:34 am ]
Post subject:  Re: Drag/centerlink oil pan clearance?
I think the bigger problem is the front corner hits the K frame. The center link helps the rear of the pan for sure. I cut and rewelded my K Frame and now I can run most any pan I want.
Author:  drgonzo [ Mon Mar 11, 2019 12:11 pm ]
You know I saw that modified K-frame you did with the tubing. I had forgotten about that. That will probably be my best solution. I have ONE early pan but I'd like to have other options or find another early pan.
Author:  Exner Geek [ Tue Mar 12, 2019 4:58 am ]
I think that a dropped drag link will allow you to use a pan from a full size early car in an early A Body. Maybe Doug knows the details.
Author:  kesteb [ Tue Mar 12, 2019 9:37 pm ]
Using the v8 center link allows you to use a Fbody oil pan. But you need to trim the front left corner to clear the k-member. I cut it back a 1/2" and weld a plate over the hole. Other pans may reguire a similar notification.
Author:  drgonzo [ Wed Mar 13, 2019 6:10 am ]
Thanks guys.
Author:  Rick Covalt [ Wed Mar 13, 2019 9:36 am ]
Here is about where I cut and boxed mine. that is an F body pan.
