Rocker shaft bolt loose
https://slantsix.org/forum/viewtopic.php?t=63387
Author:  Eltonsd100 [ Tue Mar 12, 2019 7:33 pm ]
Post subject:  Rocker shaft bolt loose
Quick question
I swapped the engine in my d100 over a year ago now and started looking at the motor that came out. It had a rocker shaft bolt finger loose ,almost completely backed out. It was suffering from low oil pressure and valve train noise. That would be a sufficient explanation for both correct ? I will keep digging as the previous owner supposedly had the head off , but I was just a little excited that with a freshen up that might be the smoking gun.
Thanks Elton
Author:  sixinthehead [ Tue Mar 12, 2019 7:55 pm ]
Post subject:  Re: Rocker shaft bolt loose
It's a good possibility, especially if it is a late engine with hydraulic lifters.
What year is the engine/truck?
As long as it is out though, you are smart to spend a few gaskets to at least look inside.
Author:  Eltonsd100 [ Wed Mar 13, 2019 4:30 am ]
It’s an 1985 with hydraulic lifters. Gaskets are cheap.
