It is currently Fri Nov 13, 2026 8:42 am
 Post subject: Throttle body
PostPosted: Fri Mar 15, 2019 7:34 am
Car Model: '67 Plymouth Fury I
I'm looking for a impco propane mixer & throttle body for my /6. I found some on ebay, but not specifically for the slant six. The guy on ebay that sells these combi's tells me I can use this mixer as well:
http://www.ebay.com/itm/IMPCO-CA125-PRO ... xyfyhRYVAZ
which is for a Ford 300 CID 6 cylinder. Would you guys agree that this throttle body can be interchanged with a slant six?
 Post subject: Re: Throttle body
PostPosted: Fri Mar 15, 2019 3:32 pm
It looks close enough to work on a slant manifold, but that doesn't mean it will fit.
We would need actual measurements of the bolt pattern and diameter of the venturi.
~THOR~
