It is currently Sat Nov 14, 2026 6:08 pm
PostPosted: Tue Mar 19, 2019 11:33 am
Car Model: 1971 Dodge Dart Swinger
Hello Everyone!
I was looking for some new motor mounts for my 71 Dodge Dart Swinger with the 225 Slant 6 and I need to pick some brains on what options I might have to get a quality set of motor mounts.
I would love to get the Poly or Poly-Locs motor mounts, but for my car they don't make a complete set, they only carry the Drivers side here: http://polybushings.com/pages/2469.html And I know that is important one, but I like things to match. :)
They do make a complete set for the 1962-66 A-Body passenger cars with the slant six which you can see here: http://polybushings.com/pages/2303-4.html
They also make a complete set for the Spool mounts of 73+ Abodies here: http://polybushings.com/pages/1105.html
My Question:
Is there a way to swap the bolt on engine mount brackets on my 71 dart slant 6 and instead use engine mount brackets from other years/styes of A-Body passenger cars with the slant six?
Even if I swapped the engine brackets for the different ones, would my current stock K-Member I have currently on the car work with the different style of motor mounts?
Any suggestions or ideas on how to make this happen would be great!
Thanks!
Tony
FYI: I did talk with Engine Swaps, and Poly Bushings just to check if they made them for my car before posting this question here. And I had read the FAQ on the motor mounts here: http://www.slantsix.org/forum/viewtopic ... 19&t=47330
Once I thought I was wrong.... but I was mistaken. :)
Here is my Ride: https://www.71dart.com/
PostPosted: Tue Mar 19, 2019 12:45 pm
I think perhaps the passenger side is same 62-76, and you could just order one of the 62-66 pass side mounts. You could look on Rockauto.com to see if the part numbers match up. Or, maybe someone else here will chime in...
Best,
PostPosted: Tue Mar 19, 2019 12:49 pm
One of the many misconceptions that floats around the automotive world is that polyurethane mounts and bushings are 'better' than rubber.
PostPosted: Tue Mar 19, 2019 1:26 pm
The cool thing about the poly mounts (that I had added the links to in my first post) is they have the interlocking metal inside them. And they look really nice, which is great also.
The Drivers side mount I can get because that mount is used for some of the V8's also. The part number on drivers side is 2265.
The Passenger side is the mount that I so far am unable to find in the poly (matching set). The part number on passenger side is 2264. Which is why I thought I would ask about switching engine mounts. (yeah sounds like alot of work but I am kinda strange, almost OCD with some things) :)
The motor mount images are from this website which can show you different motor mounts and motor mount part numbers: http://www.showmetheparts.com/anchor/
Users browsing this forum: Bing [Bot] and 15 guests
