Hesitation Blues
https://slantsix.org/forum/viewtopic.php?t=6345
Author:  sixty4dartgt [ Mon Jul 21, 2003 7:26 pm ]
Post subject:  Hesitation Blues
I got some hesitation in throttle response. The car is really slow off the line. It idles pretty well. I have installed a pertronix ign and coil. I rebult the carb (BBS) myself, so I think that is the problem. I know this may be hard to diagnose, but I had to ask. Another thing is when I wind out a gear, I gradually get more gas pedal. Is this common? If I floor it from the start, the pedal will only go down a certain amount. After about 2500 rpm, the pedal starts going down further. It's like something is opening up or something. As always, all advice\comments are appriciated.
:shock: :?
Author:  64 Convert [ Mon Jul 21, 2003 7:33 pm ]
It could be worn motor mounts flexing and causing the throttle linkage to bind. After you get moving, the engine would settle back down and relieve the binding.
Author:  sixty4dartgt [ Mon Jul 21, 2003 8:19 pm ]
I thought about motor mounts. Two things:
1. The motor has slow throttle response even with no load on the clutch (hood open, working carb by hand)
2. Would the mount have to be broken to cause the pedal restriction, or just a worn mount can cause this?
My mounts are not broken, but they do have some dry rot
Author:  Plymouth Duster72 [ Mon Jul 21, 2003 8:55 pm ]
a little of the beaten trail here...but have you adjusted your valves lately??? of course it wouldn't have anything to do with your linkage binding...that is a rod type isn't it?
-Don
Author:  sixty4dartgt [ Mon Jul 21, 2003 10:11 pm ]
It is rod linkage. I have not adj the valves. I do not know how nor have they been adj in the last 10+ years (the car was sitting for a long time before I bought it 6 months ago). What are the drawbacks of not adj the valves?
Author:  Doc [ Tue Jul 22, 2003 9:21 am ]
Here are some things to check:
Distributor vacuum advance
Distributor mechanical advance
(use a timing light, the mark should jump forward when you hit the throttle)
Carb. accelator pump. (do you see a shot of fuel when you hit the throttle?)
Valve adjustment. (tight valves kills the vacuum signal and the carb is slow to react)
Check the rod and kickdown linkage for binding. The trans throttle pressure could also cause some resistance.
Author:  Eric W [ Tue Jul 22, 2003 10:40 am ]
I don't know anything about BBS carbs, but can you go to a bigger jet like Holleys? I know this is what cured my hesitation problems.
