It is currently Tue Nov 17, 2026 5:44 pm
 Post subject: automatic vs manual
PostPosted: Tue Apr 02, 2019 10:52 am
Car Model: 1964 Dodge 330
Will a pre 1974 225 with an automatic interchange with a 3 speed manual transmission?
 Post subject: Re: automatic vs manual
PostPosted: Tue Apr 02, 2019 12:44 pm
Maybe. What year trans/flywheel?
The flywheel must be from 1968 or newer. Also the crank must be drilled and reamed for a pilot bushing. Most all slant six cranks are drilled, but not all are reamed. If not reamed, you need to use a reduced OD pilot bushing, or ream the pilot hole. Or use a late style pilot bearing ( https://www.rockauto.com/en/moreinfo.ph ... 26&jsn=438 ), if the late crank.
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 3 guests
