automatic vs manual
https://slantsix.org/forum/viewtopic.php?t=63462
Page 1 of 1
Author:  1badford [ Tue Apr 02, 2019 10:52 am ]
Post subject:  automatic vs manual
Will a pre 1974 225 with an automatic interchange with a 3 speed manual transmission?
Author:  Charrlie_S [ Tue Apr 02, 2019 12:44 pm ]
Post subject:  Re: automatic vs manual
Maybe. What year trans/flywheel?
The flywheel must be from 1968 or newer. Also the crank must be drilled and reamed for a pilot bushing. Most all slant six cranks are drilled, but not all are reamed. If not reamed, you need to use a reduced OD pilot bushing, or ream the pilot hole. Or use a late style pilot bearing ( https://www.rockauto.com/en/moreinfo.ph ... 26&jsn=438 ), if the late crank.
