Efi
https://slantsix.org/forum/viewtopic.php?t=6349
Author:  drainagain [ Tue Jul 22, 2003 10:35 am ]
Post subject:  Efi
:?: Can anybody explain, why the most simple way to go (fuel) injected is to istall a GM system (as described in Bob DiBiase's excellent article) and not some 6-cyl. model by Mopar that fits any modern V6??? Thank You!
Author:  slantvaliant [ Tue Jul 22, 2003 11:52 am ]
The way I understand it is that some EFI systems are more integrated into the rest of the car's electronics than the BOP (Buick - Olds - Pontiac) batch-fire EFI system from the early-mid 80's. On many of the other, newer systems, There can be a surprising number of inputs that could have effects on the fuel system. That means a lot of sensors you have to install, wire around, or emulate. Bob D seems to have found an available system from an engine of similar displacement and generally higher output that is fairly easy to work with. For example it is batch fired and does not require a crank position sensor. You need the EFI brain and some bits and pieces, not a couple of CPU's, multiple wiring harnesses, and a dozen sensors.
Sorry, but I have little brand loyalty when it comes to peripherals. I do like to keep Mopar engines in Mopars, and Fords in Fords, etc., but I'll take bits and pieces from any source if it improves my car. Think of it as spoils of war! :wink:
Author:  Bob D [ Tue Jul 22, 2003 4:54 pm ]
Generally Slantvaliant is right. The main reasons that I chose the GM batch fire system are:
1) This system still used a distributor.
2) The availability of parts. (Check out any junkyard)
3) The compatibility with the Buick turbo set-up. (I'm now running a Buick turbo, http://hometown.aol.com/bbobbias/page1.html ).
4) It is a MAF system and consequently is very flexible. (I'm not really sure, but I think all Mopars use speed density calibration).
I love my Slant but brand loyalty is not a priority with me. It would be interesting to see a conversion using Mopar parts but I think it would be quite a bit more difficult.
Oh, and thanks for the complement on the article. I hope it helps no matter what you decide to do.
Bob D
