It is currently Thu Nov 26, 2026 6:58 pm
 Post subject: Manifold torque
PostPosted: Fri Jul 25, 2003 5:17 pm
I should have my head back any day now, so I figured it was time to ask the question.
I know the spec'd torque for the manifold bolts is 10 ft-lbs, but this torque spec is for a stock intake/exhaust manifold, and I assume the reasoning for such a light torque spec is to allow the exhaust manifold to expand and contract somewhat "freely".
My question regards headers, when using split headers (3x2) is it advisable to tighten up this spec a bit? When I installed the supersix intake and dual outlet clifford headers about 2 years ago, i religously checked the manifold nuts as they seemed to vibrate loose and needed re-torquing about once a month. I finally got tired of it and cranked them to 15 ft-lbs. This lasted a little longer, but the nuts still needed re-torquing every 6 weeks or so. When i cranked them all to 20 ft-lbs they stayed put. Is this adviseable? Or should i just live with re-torquing the manny bolts every month?
If it helps, here is my new combo:
'87 225 block .080 over
crank cut .020/.020
head shaved .060, ford 300 valves, C/R 9.3:1
MSD 6A ignition/wires/coil
Offy intake w/ 390 cfm holley
Clifford 3x2 headers w/ 2.5" duals thru Twin Flowmaster 40 series
MP Purpleshaft Cam .398 lift, 240 dur (hydraulic)
FWIW-the stock manifolds never loosened up at 10 ft-lbs.
-S/6
PostPosted: Sat Jul 26, 2003 1:14 am
Check out www.stage8.com They make header fasteners that are supposed to not come loose. I have a cataloge that lists part number 6915 for slants. They do work! I have a buddy who's brother put a 400 in a '69 Barracuda using stage 8 fasteners on his headers, and he has never had to touch them. Good product.
 Post subject: I go tighter
PostPosted: Sat Jul 26, 2003 3:14 pm
I have Dutra duals with an aluminum intake. I probably torque closer to 20ft #'s. So far I see no problems, only advantages of better sealing. The culprit before was the exhaust which gets much hotter than the intake and therefore moves back & forth a whole lot more. Happy torquing.
Cheers!
Al T
