It is currently Fri Nov 06, 2026 5:20 am
PostPosted: Fri May 03, 2019 10:42 am
The '71 904 I bought doesn't have the speedo drive retainer and bolt. Will the one from my '63 Push Button 904 work or do I need to start looking for one?
Thanks,
Brad
PostPosted: Sun May 05, 2019 7:10 am
The earlier style will not fit the later style. The speedo gear is completely different between the two. Any late 60's to mid 80's automatic should be the same as what you need. 904 and 747 are the same.
PostPosted: Sun May 05, 2019 5:27 pm
Thanks Matt. That's what I needed to know.
