It is currently Sat Nov 07, 2026 2:11 pm
PostPosted: Tue May 07, 2019 3:20 pm
Did anyone ever make a steel bellhousing for the Slant Six? By 'steel' I mean a 'race' type bellhousing like Lakewood made for V8's.
PostPosted: Tue May 07, 2019 4:06 pm
Car Model: Toad Wagon
Quicktime. They come with adapter rings for two case nose sizes. They're around $800.00 now, and show up on Ebay from time to time.
Here's one (of seven) at the moment.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Tue May 07, 2019 4:34 pm
Hmm, thanks! That's a lotta dough but I give them credit for making it.
I guess I could modify a stock aluminum bell....machine off the back and weld on a plate. Harder to work in aluminum but probably not too bad.
Thinking of what it would take to fit up a T56 Viper 6 speed....I bought one in 2000 that, 19 years later, I've still never used for anything.
I'm guessing the Slant would have a tough time pulling the .5 6th gear with the 2.76 rear end!
PostPosted: Tue May 07, 2019 4:56 pm
Well if all else fails wilcap can make you a nice adapter for that combo.
If you have a 6th gear of ~0.5ish why not use a 4.10-4.56 axle ratio with that trans?
PostPosted: Tue May 07, 2019 7:48 pm
Car Model: '23 T-bucket
Hmmm. Sounds like just the package for a Bonneville car.
Roger
PostPosted: Tue May 07, 2019 8:07 pm
Where am I gonna find 4.56's for the 7-1/4"??? :lol:
PostPosted: Tue May 07, 2019 8:09 pm
The ratio isn't .5-ish, it's .5 exactly lol.
My first (modern) Challenger had the same ratios, and when you go into 6th it's unmistakably 'cruise only' time. My current Hellcat has the same gearbox but different ratios and 6th is .77 (I think) which is a lot more useful
Edit:
Hellcat ratios are 2.26, 1.58, 1.19, 1.00, 0.77 and 0.63:1. Meanwhile, the naturally aspirated (non-supercharged) 6.4-liter 392 HEMI V8 with its 485 horsepower and 475 lb-ft of torque has the following gear ratios: 2.97, 2.10, 1.46, 1.00, 0.74, 0.50:1
PostPosted: Tue May 07, 2019 9:11 pm
I bet charrlie has one.
PostPosted: Wed May 08, 2019 3:54 am
Not 4.56. How about 5.13's ? :twisted: :twisted: :twisted:
PostPosted: Wed May 08, 2019 5:11 am
Wow. Well, that would certainly allow me to take advantage of the Slant's broad RPM range lol.
But even 5.13's would be 'transformed' into 2.62's with the OD....
PostPosted: Wed May 08, 2019 6:00 am
with the torque of a turrrrrrboooo slant or a torqstorm that would be perfect.
PostPosted: Wed May 08, 2019 7:27 am
I would have doubts about the tiny 5.13 pinion gear, being able to handle the torque of a boosted slant.
PostPosted: Wed May 08, 2019 9:33 am
yeah charrlie, you are probably right.
I would say that if you have she ca$i$h to buy a viper transmission you could easily buy an 8.25 or 8.75 with the ratio needed tgo make the trans work.
PostPosted: Wed May 08, 2019 1:18 pm
I really don't want to ditch the 7-1/4"....I have a stack of 8-3/4's I could use, but that would kinda be like tossing the 6 for a V8. I'm attracted by the lower losses and lower weight of the 7-1/4".
The Japanese for whatever reason have some rear's with similar sized ring gears that are plenty tough.
As for the money to buy a T56....that's '19 years ago' money which is basically the same as 'free' now, lol.
PostPosted: Wed May 08, 2019 1:48 pm
If you gear it deep enough to use the 6th you probably won't use 1st unless you are towing a 30' trailer to the track! :D :D
Users browsing this forum: Amazon [Bot] and 1 guest
