Hyper Pak Carb Throttle Linkage, comments welcome!
https://slantsix.org/forum/viewtopic.php?t=63628
Page 1 of 2
Author:  hyper_pak [ Thu May 16, 2019 4:17 pm ]
Post subject:  Hyper Pak Carb Throttle Linkage, comments welcome!
I have been working on this for a while now. When I ran the manifold in the race car, I had a custom bracket and a part off a helicopter to control the carb. For the wagon I wanted to go as stock as possible at least as far as looks and my parts and pieces. Johannes in Germany cast me a front bracket and I have been cutting and fitting parts to make it look right and work right. I have been using the XNR and Asimmetrica pictures as examples. Here are the first mock-up pictures. Take a look and see if you can see any issues or better ideas for what I have fabricated. Thanks.
Author:  Badvert65 [ Thu May 16, 2019 4:51 pm ]
Post subject:  Re: Hyper Pak Carb Throttle Linkage, comments welcome!
Will you have any flex issues with that long rod? Everything looks good, though.
Author:  hyper_pak [ Thu May 16, 2019 6:23 pm ]
I did think about that, and this is a 170, if someone runs a 225 the angle would change again. I don't know if Chrysler had a different part number for a 225 shaft or a 170 shaft. Here is what I have seen over the years.
Author:  dbussey1 [ Fri May 17, 2019 6:31 am ]
Looks pretty clean to me
And greetings from just up the road in Dallas!
Author:  Exner Geek [ Fri May 17, 2019 8:00 am ]
If you are okay with a dual master cylinder, I would consider a Lokar cable set up and a push-pull throttle instead of that whirly gig. Just my 2 cents.
Author:  Badvert65 [ Fri May 17, 2019 8:16 am ]
With enough support for the linkage (to reduce flex) I think that setup would work just fine. What about kick-down linkage? Assuming you are running an automatic.
Author:  THOR [ Fri May 17, 2019 10:22 am ]
If you look at the firewall, you'll see he was able to retain the factory linkage, which means his kickdown is likely unaffected.
This looks like a really clean way to make it work!
~THOR~
Author:  hyper_pak [ Fri May 17, 2019 12:44 pm ]
Hello! Send me a PM and we can talk!
Author:  hyper_pak [ Fri May 17, 2019 12:55 pm ]
I have made some changes for safety, dual circuit MC, but I want the linkage to be as stock as I can. Keeping my pedal, and kickdown as mentioned. I have never seen stock linkage in person so I am working from photos. The long rod on the yellow towel has the kickdown linkage. Even the Daytona Valiant had a similar rod and it looks like they were using the kickdown as a return spring. I don't think the package was recommended for an automatic transmission. So some stuff I am experimenting with.
Author:  62 val [ Fri May 17, 2019 4:57 pm ]
Clean install. My rotating rod is like yours but my linkage from the rod to the carb is different. It has ball and socket ends and adjustable rod?
Author:  hyper_pak [ Fri May 17, 2019 6:38 pm ]
62 Val, can you post a picture? If I look at the promo picture close it has the ball and socket style. The XNR and Asimmetrica have the other style, like a manual transmission to shift rod style. I am working on each, just looking for some small parts in the mail.
Author:  Dart270 [ Sat May 18, 2019 3:15 am ]
You're completely mad, Stan! I guess I'm with Seymour... Gotta have something to play with though, eh?
Can't wait to see the project tearing up a track,
Author:  hyper_pak [ Sat May 18, 2019 8:20 am ]
Hey Lou, aren't we all a little crazy?
And some of the pictures of linkage I have seen on a few set-up make mine look simple!
I also want to make a few passes, but just to drive it will be a reward.
I got some of the threaded parts yesterday, seeing what I can do. I have a couple of parts I found, 1/4-32 thread! Weird.
Author:  Danarchy [ Sat May 18, 2019 11:26 am ]
Looks Great! The length of the rod would be my only concern. Any way to have a (carrier bearing type) support mid way?
Author:  Rick Covalt [ Sun May 19, 2019 1:24 pm ]
Stan, there is a 62 Lancer GT on EBay right now that has the Hyperpak intake and exhaust on it. It has some pics of the linkage.
Rick
Page 1 of 2 All times are UTC-08:00
