| 65 4 speed a833 to 77 slant aluminum bellhousing? https://slantsix.org/forum/viewtopic.php?t=63674 |
| Author: | Derfuhrerofrust [ Thu May 30, 2019 6:42 am ] |
| Post subject: | 65 4 speed a833 to 77 slant aluminum bellhousing? |
Title kinda says it all. I have what I believe is a 65 and a 77 3 w OD bellhousing. Will this work? Any feedback is appreciated. |
| Author: | ski [ Thu May 30, 2019 7:09 am ] |
| Post subject: | Re: 65 4 speed a833 to 77 slant aluminum bellhousing? |
That bell has a larger bearing retainer hole. You would need some type of adapter ring and possibly have to fiddle with the Z bar placement on the bell. |
| Author: | Greg Ondayko [ Thu May 30, 2019 9:46 am ] |
Your transmission is a 65 and the bellhousing in Aluminuim from a 77 model correct? To do that you need something like what is disvussed here.. https://www.forabodiesonly.com/mopar/th ... ng.323153/ Not sure if anyone makes one... but a local machinist could get you one made. Greg |
