It is currently Mon Nov 16, 2026 12:14 pm
 Post subject: Distributor removal
PostPosted: Thu Jun 27, 2019 4:23 am
Car Model: 1983 D-150
1983 D-150 Slant Six 89K on the clock. I went to remove the distributor and the darn thing wouldn't come out.
I completely removed the hold down and still wouldn't pull out. As you pull it sounds like it's hitting a pin, any thoughts?
Second question, I've replaced the clutch on this vehicle recently and bought what the book called for which was a 11" flywheel and clutch set. To my surprise not the right size, I needed a 10 1/2", so I wound up having to cut the flywheel instead of a new one. It seemed my choice of 10 1/2" clutch sets was limited. Could I have used the 11"??
Thanks in advance
 Post subject: Re: Distributor removal
PostPosted: Thu Jun 27, 2019 8:14 am
They can get crud built up on the stem of the distributor which makes it hard to pull out. Try lots of soaking with penetrating oil and/or carb cleaner and lots of twisting/pulling.
PostPosted: Thu Jun 27, 2019 11:27 am
10 1/2 clutch choices should be wide opean. Do you have the np435 or a833 od trans?
1976 Feather Duster /6 4sp
1984 W100 318 727 np241
1972 'Cuda 340 4sp
1985 D250 360 46RH
PostPosted: Thu Jun 27, 2019 1:37 pm
It has an overdrive, so my guess would be A833.
PostPosted: Thu Jun 27, 2019 6:06 pm
If you have the 833 OD then you will only have a 10" clutch max. There are not a lot of great options for that size clutch.
PostPosted: Fri Jun 28, 2019 3:26 am
Interesting, would you point me in the direction of a flywheel and clutch set stronger then OEM?
