| idle problem https://slantsix.org/forum/viewtopic.php?t=6375 |
| Author: | guest [ Fri Jul 25, 2003 3:21 am ] |
| Post subject: | idle problem |
I have a 65 plymouth barracuda, and I have two problems. I just replaced both manafolds, and rebuilt the carburetor. The old exhast manafold had cracks on both sides, and all the way through. The engine idles low, and seems to start fine, but once running stales when put into gear. It also stales at stops signs. I am a beginner at this stuff, so I have no idea how to change the idle. Ok, the second problem is, the engine seems to rock a bit when running. I have not checked the mount bolts, but I will soon. I heard if I clean the points under the distributer, it would help. Any other ideas would be appreciated. Any comments would be great, I really need some advice from a fellow slant 6 owner. -John, slant 6 225 |
| Author: | Pierre [ Fri Jul 25, 2003 4:42 am ] |
It has been so long since I used an original carb so I can't comment on where the adjusting screws are, but if you are still using points type ignition, you want to upgrade to electronic ignition, either the mopar style or aftermarket such as msd or crane brand. Relatively simple and easy upgrade with good results. You will need a magnetic pickup distributor, some lengths of wire, and either the mopar, msd, or whichever box you decide to use. The wiring diagram for the mopar electronic ignition is contained in an article off of the main page for this site, the aftermarket ones are usually availible on the respective makers website. BTW - check a factory service manual if you have one. I believe it has carb adjustment guidelines. |
| Author: | Dennis Weaver [ Fri Jul 25, 2003 10:48 am ] |
...time to learn how to do a basic tune up. If you don't already have these items, go buy them: Timing light, feeler gauges, and also dwell/tach and vacuum gauge if you really want to do it right. Then report back. Does Pertronix offer a conversion kit for a /6 folks? I installed one on a V8, and I think I remember reading here that they do. That is the simplest thing for doing away with the points for a beginner. If you've already successfully swapped the intake/exhaust manifolds, John, you definitely jumped right in and got your feet wet and are well on your way to being a /6 wrench jockey. The manifold job is a pain in the butt. "DW" |
| Author: | mighty mouse 63 [ Fri Jul 25, 2003 10:51 am ] |
Have a petronix conversion in my 6, been working flawsely for over 5 years....Dave |
| Author: | v8440 [ Fri Jul 25, 2003 1:38 pm ] |
Just turn the idle speed up a bit before jumping into everything else. You do that by turning the idle screw clockwise. If you don't know which screw that is, first warm the engine up some so that the choke will be open. Then, shut off the engine and remove the air filter and housing from the top of the carburetor. Now, have someone get in the car and press the accelerator pedal with the engine off. Look for the arm on the carburetor that the throttle linkage moves. When the person in the car lets off the pedal, that arm will swing back to the idle position. In so doing, it will contact a screw. That screw is the idle speed screw. Turn it clockwise to speed up the idle. The reason you want the choke open is that when the choke is closed, the idle speed is controlled by a different screw. Adjusting that will only control the idle speed when the engine is cold. Warming the engine up gets the choke mechanism out of the picture, which guarantees that you will adjust the correct screw. |
| Author: | guest [ Sat Jul 26, 2003 2:33 am ] |
| Post subject: | thanks |
Hey, Thanks to everyone for you help! I think this is one of the most valuable resourses for me, as far as my car goes. Thanks again! John, slant 6 225 |
