| Distributor Grease https://slantsix.org/forum/viewtopic.php?t=63768 |
| Author: | crickhollow [ Thu Jun 27, 2019 10:44 pm ] |
| Post subject: | Distributor Grease |
What type of grease/oil should I use on my dizzy? I have a 62 Valiant with a Bosch dizzy which has been completely dismantled and cleaned. Thanks |
| Author: | DadTruck [ Fri Jun 28, 2019 7:45 pm ] |
| Post subject: | Re: Distributor Grease |
for the shaft, I use a quality synthetic grease like Mobil 1 Red, although engine oil would also suffice for the pins that the centrifical advance weights run on, I use a thin coating of dry film moly, as found at http://kanolabs.com/indLub.html that way you don't have a wet lube that will hold debris or run off |
