| Flexplate- do i need anything special? https://slantsix.org/forum/viewtopic.php?t=63772 |
| Author: | drgonzo [ Fri Jun 28, 2019 6:52 pm ] |
| Post subject: | Flexplate- do i need anything special? |
I have a 225 with a 250* cam, 10.6:1 CR, big valves, ported head, etc. and a 3200 converter. Do I need to modify an aftermarket V8 flex plate or will a stocker be OK? I do plan to race a bit. |
| Author: | Rick Covalt [ Sat Jun 29, 2019 4:31 am ] |
| Post subject: | Re: Flexplate- do i need anything special? |
I bought a real nice V-8 one from 440source that is literally 2 times as thick as the stock one. I have had trouble with them coming loose at the convertor bolts and the stock ones wearing at the holes. This one has a solid body too. No large cutouts on it. http://store.440source.com/Flexplates-F ... oducts/24/ |
| Author: | Greg Ondayko [ Sat Jun 29, 2019 6:11 am ] |
I get a sb sfi approved one, one of tje crank holes would need to be re drilled as its off. The other 5 holes line up. After drilling i welded the offset hole shut. Lots of loctite red on crank bolts as well as converter bolts. If you look through the ruster thread it probably documented there. Greg |
| Author: | Rick Covalt [ Sat Jun 29, 2019 8:42 am ] |
The one I got is the SFI one without the sticker. It is the exact same one according to their site and is $20 less without a sticker. I have drilled flywheels and flexplates for V-8 to fit the Slant 6 and never welded up the holes. Since it is close to the centerline of the crank it does not affect the balance near as much as if it was further out. Not saying you should not weld your up, just that I didn't and didn't notice any problems. |
| Author: | drgonzo [ Sat Jun 29, 2019 10:52 am ] |
Thanks guys. I will get the better V8 plate. |
| Author: | drgonzo [ Sat Jun 29, 2019 6:29 pm ] |
Quote: The one I got is the SFI one without the sticker. It is the exact same one according to their site and is $20 less without a sticker.
Rick, does that one work with the 904. I have heard of some of them interfering with the starter. I think you are using a 904. Correct?
| Author: | Rick Covalt [ Sun Jun 30, 2019 4:17 am ] |
Yes it does, and yes I am. |
| Author: | drgonzo [ Sun Jun 30, 2019 12:43 pm ] |
Dumb questions are kind of my thing. |
| Author: | slantzilla [ Sun Jun 30, 2019 12:56 pm ] |
I have one of the Mopar Performance ones. I egged the one bolt hole out with a die grinder and called it a day. I got some of the Cox Bros/MP ones from Mike when I acquired his stuff. They welded the hole up and redrilled it. With the flywheel bolts in they look identical. Make sure that whatever one you get has the correct size holes for your converter bolts. |
| Author: | Rick Covalt [ Sun Jun 30, 2019 1:01 pm ] |
Yes I believe the one I got had 3 sets of holes. |
| Author: | Ron Parker [ Sat Aug 10, 2019 6:57 pm ] |
I tore a slant flex in two when I shifted to second gear it looked like a saw blade I also bought one from cox bros if I remember it was 340 flex plate welded up and re drilled it is stiil in the car. thanks ron parker ps bagel I have tried several times to contact john cox with no luck do you have any ideas your racing buddy possum |
| Author: | slantzilla [ Sat Aug 10, 2019 7:47 pm ] |
John and Jim parted ways Ron. I saw Jim a couple years ago at the Indy Cylinder Head swap meet. He still has a little Slant stuff, but not a whole lot. I have his number somewhere. If I find it I'll pm it to you. |
| Author: | Ron Parker [ Sun Aug 11, 2019 6:22 pm ] |
jim iswho I ment I new about john and jim if you find it shoot it to me thanks possum ps I am scheduled to be out of therpy Friday an go home thanks bagel |
