It is currently Thu Nov 26, 2026 6:22 pm
 Post subject: Oil pressure problem?
PostPosted: Wed Jul 23, 2003 1:38 pm
Just rebuilt a 71' 225 in a Valiant. The oil pressure when hot in drive hovers around 15-20 psi. When driving around town it goes up to 50-55 psi. Is this normal, or did I maybe forget to put in an oil galley plug perhaps? Also, I put a few extra shims in the pump to try to help the pressure at idle, but it didn't help.
PostPosted: Wed Jul 23, 2003 1:53 pm
That's sufficient pressure @idle. 50-55psi sounds good. You can shim that spring all day long, and it's not going to make a difference at idle. The relief valve is already closed. The only thing that will help is a higher volume pump, but your pressures already seem fine to me.
"DW"
If it ain't broke, fix it!
PostPosted: Wed Jul 23, 2003 2:23 pm
Which oil pimp did you use? (there are 3 rotor sizes available)
Is it a new oil pump?
Was the crankshaft reground?
What are the bearing clearances?
Were the cam bearings changed?
Your problem is not caused by a missing oil galley plug, if that were true you would have zero oil pressure.
PostPosted: Wed Jul 23, 2003 10:23 pm
I'm sorry, Doc, but where is the problem? Chrysler specs call out 8psi min@idle and 30 to 70psi@2000rpm and above. I'm assuming this is a stock motor, pump, etc. I don't see a problem at all.
"DW"
PostPosted: Wed Jul 23, 2003 11:19 pm
You just described the oil pressure on my slant. No worries. 8)
PostPosted: Thu Jul 24, 2003 5:56 pm
Doesn't reworking the stock oil pump also help up the idle pressure a bit?
PostPosted: Thu Jul 24, 2003 9:43 pm
"DW"
15-20 psi of hot idle oil pressure is OK, I would expect a bit more from a "rebuilt" engine.
Guess I was just trying to get a little more information.
Sounds like the bearings may be set on the loose side.
At this point he may as well just run the thing and see if the oil pressure stays in that area over time.
PostPosted: Thu Jul 24, 2003 10:17 pm
I see. I have a bone stock /6 in Kermit, my '72 Valiant. I got the "stock" Melling replacement pump with the slightly thicker rotors, and with new rod bearings and original main bearings, it'll hold around 30-35psi hot at idle, as I remember. 55psi going down the road with a small shim added under the relief spring and SAE 30. Scampede, what oil are you running? Maybe that is playing into the equation.
"DW"
 Post subject: more
PostPosted: Thu Jul 24, 2003 10:51 pm
I agree. Heat and multi vis are not real compatible.
'66 Cuda 225/4spd
'64 Dart GT 340/4spd
 Post subject: Re: more
PostPosted: Sat Jul 26, 2003 4:48 pm
Right now I am running straight 40 in it.
After hearing some peoples responses, I am starting to think I was maybe worrying about nothing. Still may possibly check clearances once winter comes though. Thanks for the imput everyone.
PostPosted: Sat Jul 26, 2003 8:21 pm
I know I probably shouldn't talk seeing as how I like to use SAE 30 among other things, but don'tcha think 40 is kinda some thick goop to run in a freshened up engine?
"DW"
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 4 guests
