| I've bought a two barrel manifold. What plugs into the ports on runner #6.? https://slantsix.org/forum/viewtopic.php?t=63825 |
| Author: | CrisandJenn [ Sun Jul 14, 2019 3:40 pm ] |
| Post subject: | I've bought a two barrel manifold. What plugs into the ports on runner #6.? |
It's got two bungs/ports which seemed to have two lines going into one and the other had a single line. Any help appreciated. I'll be putting the BBD I bought from Dan onto the manifold. The lazy man within me says just plug them and move on~ :-0)~ Thanks in advance, Cheers, Cris |
| Author: | Reed [ Sun Jul 14, 2019 4:09 pm ] |
| Post subject: | Re: I've bought a two barrel manifold. What plugs into the ports on runner #6.? |
One is an air charge temp sensor fitting, the other is the vacuum tree fitting. If you have no vacuum operated accessories, you can just plug them both. |
| Author: | CrisandJenn [ Mon Jul 15, 2019 9:53 am ] |
Awesome, thanks for the info.! Nothing vacuum operated on her truck so plugs it is. Thanks again, Cris |
