| Temperature sender won't fit. https://slantsix.org/forum/viewtopic.php?t=63828 |
| Author: | drgonzo [ Mon Jul 15, 2019 4:58 am ] |
| Post subject: | Temperature sender won't fit. |
Started to install the temperature sender in my newly installed engine and it just falls into the hole. My block is a 5 freeze plug model but the numbers just below the cylinder head are gone and have 225 030 stamped there. The normal location for the sender appears to be 1/4 npt threads. Is there a sender that will fit those threads? What are my options here? Just a quick google search turns up a classic instruments SN23 with the correct threads. Thanks, Brad |
| Author: | emsvitil [ Mon Jul 15, 2019 5:04 am ] |
| Post subject: | Re: Temperature sender won't fit. |
You could just use a npt to npt adapter...………. |
| Author: | Greg Ondayko [ Mon Jul 15, 2019 5:53 am ] |
Yep just use a hardware store adapter / pipe thread reducer collar. Greg |
| Author: | drgonzo [ Mon Jul 15, 2019 6:08 am ] |
I knew some of you would know. I had it in my head that the sender was some odd kind of thread. I walked down the street to Car Quest and got the bushing I needed. Problem solved. Thanks guys. Brad |
| Author: | Dart270 [ Mon Jul 15, 2019 6:55 am ] |
You are lucky you have the large hole already. I drill/tap all of mine early heads out now so I can use different sensors as I wish. Hardware store will fix you up, as others have said. Lou |
