| Carb and Pertronix Conversion https://slantsix.org/forum/viewtopic.php?t=6383 |
| Author: | guest [ Sat Jul 26, 2003 2:39 am ] |
| Post subject: | Carb and Pertronix Conversion |
Ok, I have read up on what you guys said to do, and I have two new problems. One, where do I get a Pertronix Conversion for my slant 6 225? The second is, where do I get a 4 bbl carb that I can change for my stock carb? Websites would be great. Thank you guys so much for your help! John, slant 6 225 |
| Author: | Dennis Weaver [ Sat Jul 26, 2003 2:53 am ] |
John, unless you plan on doing a bunch of other modifications (i.e. cam, exhaust work at the very least), I'd recommend you don't get any more drastic than a 2bbl factory super six setup. You can bolt a four barrel on your otherwise stock engine, but I betcha it'll run like crap. Check out the great info in the articles section (yeah, it took me a while to notice they were here, too "DW" P. S. - You must be a real masochist wanting to do that manifold job again so soon! |
| Author: | guest [ Sat Jul 26, 2003 12:03 pm ] |
| Post subject: | ok thanks |
dw, Haha, Thanks, You see it is this kinda stuff I need to learn. Although I already replaced most of the exhaust. Thanks for the advice. John slant 6 225 |
| Author: | Charrlie_S [ Sat Jul 26, 2003 4:21 pm ] |
John, might I suggest, you register on the site, and log in. That way you will not show up as "guest". |
| Author: | Matt Cramer [ Mon Jul 28, 2003 5:07 pm ] |
| Post subject: | Sources |
A lot of the mail-order places carry the Pertronix. Summit and J.C. Whitney come to mind. Your local speed shop could probably also order one for you. |
| Author: | Daddiojoe [ Fri Aug 01, 2003 8:33 am ] |
| Post subject: | Our friends at Ebay |
I was able to score a Pertronix Stage I and a hi-po coil from a guy on Ebay for less than $100. There's a shop that sells Petronix and even if they aren't posting any for the /6 they can order it for you. Sorry I forget the name. Good luck, Joe |
| Author: | Pierre [ Fri Aug 01, 2003 2:36 pm ] |
On the note of running a 4 barrel on a stock engine - I tried running a holley 8007 (390cfm vacuum secondaries) on my motor (stock, other then clifford manifold and dual shorty headers with single 2 1/4" pipe to the back). Out of the box, I couldn't get it to run right. I spent a bit of time fiddling, but to no avail. My next step was to tear into it and replace the jets etc to what was recommended, but I decided to take a different route all together. |
