| Recommended timing gear set manufacturers? https://slantsix.org/forum/viewtopic.php?t=63830 |
| Author: | Jase [ Mon Jul 15, 2019 3:10 pm ] |
| Post subject: | Recommended timing gear set manufacturers? |
I just picked up a take out engine for my plow truck project. The crankshaft moves about 8-10* before the distributor rotor starts to move, so I am assuming the timing great may be worn.. Any of the following manufactures preferred over the others for a stock to mild refresh? Cloyes, Engine Tech, and Sealed Power look about the same from the pictures at Rock auto.. The Melling one looks very skimpy and I would not trust it as wall art... |
| Author: | Greg Ondayko [ Mon Jul 15, 2019 5:25 pm ] |
| Post subject: | Re: Recommended timing gear set manufacturers? |
https://rover.ebay.com/rover/0/0/0?mpre ... 3561511658 This is a very nice set. Hit the inside of the lower gear with a drum sander or dremel as its usually a tad tight to install even with the proper installation tools. Greg |
| Author: | Jase [ Mon Jul 15, 2019 7:43 pm ] |
Good to know, I will keep an eye out for another auction to turn up.... Thank you. |
