It is currently Thu Oct 01, 2026 12:20 am
PostPosted: Thu Jul 11, 2019 3:01 pm
No instructions came with the converter on torque specifications. What should I torque these 7/16 fine thread bolts in my Edge Converter?
What about it fellows?
PostPosted: Thu Jul 11, 2019 5:52 pm
The spec would be about 55 ft-lbs (like flexplate to crank bolts), most likely. For 7/16", personally I would go at least 60-65, and use locktite.
PostPosted: Thu Jul 11, 2019 7:11 pm
Thanks Lou. I should be good at 60# with red loctite.
