Alternator bracket
https://slantsix.org/forum/viewtopic.php?t=63837
Page 1 of 1
Author:  Laxmoparman [ Wed Jul 17, 2019 8:54 pm ]
Post subject:  Alternator bracket
Hey guys. Had a quick question. I had to replace the head gasket on my slant and during the removal of the head I accidentally broke the alternator bracket. I found one online from a 72 Duster with the slant 6. Will that be the same? Looks like the same bracket but thought I would ask first.
Author:  Dart270 [ Thu Jul 18, 2019 2:50 am ]
Post subject:  Re: Alternator bracket
I assume this is the standard passenger side mounting. Those mounts should bolt up and be fully compatible, although they may look a little different. Between 67 (your car) and 72, then should look essentially identical and be a lump of cast iron. Some later and earlier ones were thick stamped/sheet metal.
Author:  Laxmoparman [ Thu Jul 18, 2019 5:06 pm ]
Thanks dart 270. It is a standard passenger side mount. I thought it looked the same but thought I would ask before I buy it.
