| 86 Ramcharger v8 radiator with slant six https://slantsix.org/forum/viewtopic.php?t=63845 |
| Author: | Tim Keith [ Fri Jul 19, 2019 7:46 pm ] |
| Post subject: | 86 Ramcharger v8 radiator with slant six |
Will the v8 radiator, shroud, and hoses from a Ramcharger work with a slant six in a 'D150. Both trucks are 1986. |
| Author: | Reed [ Fri Jul 19, 2019 8:11 pm ] |
| Post subject: | Re: 86 Ramcharger v8 radiator with slant six |
Yes! Provided you use a flexible upper radiator hose since the V-8 radiator puts the upper hose on the opposite side of the radiator from the slant six. |
| Author: | Tim Keith [ Fri Jul 19, 2019 11:43 pm ] |
You're correct Reed. I just noticed that I first registered to this forum a day before you back in 2002. |
| Author: | Reed [ Sat Jul 20, 2019 9:55 am ] |
Quote: You're correct Reed. I just noticed that I first registered to this forum a day before you back in 2002.
Time flies. |
| Author: | afastcuda1970 [ Sun Jul 21, 2019 7:58 am ] |
I put a v8 radiator in my '84 W150. I used the v8 upper hose but had to trim. The v8 rad has a larger diameter lower hose so I had to use an adapter. The v8 shroud didn't fit. I had to elongate the bolt holes in the slant shroud to make it fit. |
| Author: | coconuteater64 [ Wed Jul 31, 2019 9:58 am ] |
I have a 4 core brass radiator from a D-350 tow truck equipped with a 360 in front of my slant and used the stock slant shroud. Like already mentioned, just use a flex hose. Keeps it nice and cool even in 105 degree weather. |
